Pin Locations
I've seen different sites that vary their facts/opinions on ECU Pin Locations. Is it labeled as:
A)
1 2 3 4 5 6 7 8 9 10
11 12 13 14 15 16 17 18 19 20
or is it labeled as:
B)
1 3 5 7 9 11 13 15 17 19
2 4 6 8 10 12 14 16 18 20
A)
B)
the old question which is which? depends on how u look at it. the factory which some people follow read 123.... from left to right. but however some people read 135.... up and down. 1 way to tell by reading the location of the injector wires. cause they go by 123... but if they read like 1 (Injector 1) 3 (injector 2) ect.. then it's up and down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WickedKP »</TD></TR><TR><TD CLASS="quote"> 1 way to tell by reading the location of the injector wires. cause they go by 123... but if they read like 1 (Injector 1) 3 (injector 2) ect.. then it's up and down.</TD></TR></TABLE>
Never thought of that. It's labeled 1, 3, 5 ... on top. Great news since that's what I used. I know I should've asked prior to the swap. Just got a little antsy. Thanks.
Remember and double check yourself, cause with 50 wires, it can get a little confusing, thsoe pins are counting looking into the ECU socket.
So when you are looking at the wiring harness plugs, it is in reverse.
-PHiZ
-PHiZ
boostedcivichatchbacksi
12
Oct 18, 2004 11:52 AM
