swap ?
ok i got a 98 civic with a 00 si b16 ,00 si ecu ,and 98 civic ex harness rewire to fit the ecu.ok my question is my check engine light turns on one i a while it throws code 14 ,which is the iacv,ill reset the ecu and it will go away for a while but then it will come on after a couple of days .does anybody know what i can do to get rid of that problem ?
the iac valve works fine i already check it.
Check your wires using a digital multimeter and make sure the wires are good with no open circuit.
If the wires are good, then I would recommend cleaning the IACV using brake/carb cleaner. Reset your ECU and test that.
If that fails, then replace the IACV.
