tranny and ecu for b16a2
im doing a jdm b16a2 swap into a eg coupe the motor doesnt come with a tranny or ecu what is the best setup for this car if it helps i will be building this car for auto-x oh yeah i have a hook up on a gsr tranny i just dont know if it would be good for what i want to do with the car
thanks,
Derek
Modified by delpoop! at 7:42 PM 8/26/2003
thanks,
Derek
Re: tranny and ecu for b16a2 (delpoop!)
best ecu use, use either a p30, or a p28. p28 can be found in a 92-95 ex... will have to be chipped. can be ran w/out knock or o2 sensor. p30 found in b16 del sols. doesn't have to be chipped, but must wire in knock sensor.
for tranny find one from the del sol b16, or the 99-00 SI. GSR tranny's gear ratios are two short for the high reving b16.
B16EJ
06-26-2003 08:58 AM
