can an obd0 distributor be repinned to obd1?
id like to know if i can use an obd0 distributor in an obd1 car by repinning the obd0 dist with obd1 connectors.... has this been done before? i've heard that you can make obd2 dists work with obd1 but i want to make sure about obd0...
thanks
thanks
Re: can an obd0 distributor be repinned to obd1? (highvelocitynyc)
No- OBD0 vs. OBD1/2 is completely different. You'll need an actual OBD1 dist. or re-pin an OBD2. You can do a search for how to repin an OBD2, it is really easy.
Re: can an obd0 distributor be repinned to obd1? (Bnjmn)
you can actually re-pin the distributor, but it will not work with the obd1 ecu. the reason for that, is that the obd1 distributor has more pickup tabs on the shaft, than the obd0 distributor.
ryanangelo212
03-18-2013 12:23 AM
