JDM B16 OBDI into EJ
I will be swapping the said engine into a 1995 EX 5spd.
Will I be loosing my power steering and A/C?
Is there anything that I should watch out for or is it just replacing my old stuff w/ the new?
I ordered a complete change over from hmotorsonline.com
Will my exhaust bolt up to the header or the cat(not sure if the swap comes w/ the header or cat also)?
Will I need to tune anything? I will only be running intake and exhaust for a couple months.
Re: JDM B16 OBDI into EJ (2camsaam)
You can retain both power steering and A/C with no problem. You'll need to get a Del Sol VTEC A/C bracket and more than likely an Integra PS pump. Just check to see if you PS line will mount to the pump on the B16 first if it came with one.
Chance EG
12
02-06-2018 07:06 AM
2hondafreaks
10-21-2009 04:39 AM
jdmmugeneg6
07-11-2004 10:30 AM
