Need help with OEM MAP sensor wiring
Old Aug 26, 2003 | 02:40 PM
nolimits's Avatar
Default Need help with OEM MAP sensor wiring
I had a broken plastic plug on my harness and decided instead of soldering another on I'd just push the pins out and reinsert them into a good plug. Simple enough procedure, but I got a little hasty and didn't mark the correct order of the wires. With the harness plugged into the sensor and viewing from the passenger side of the car (rear of plug) I put them in the following order (left to right) : Yellow/Red, Green/White, Red/Green. Would someone please check this and confirm it. It's a 00 Civic SI harness. I'm in the process of an engine swap and don't want any trial and error bs when I'm ready to start it up. Thanks!!
Old Sep 16, 2003 | 08:47 PM
DropSquadCivic's Avatar
Default Re: Need help with OEM MAP sensor wiring (nolimits)
you got it right
thez6kid
Engine Management and Tuning
May 13, 2012 04:46 PM
russd210
May 22, 2011 11:35 AM
HaveNoLife
Feb 28, 2005 05:22 PM
zlambe
May 10, 2004 05:22 PM
