H22 guys.. OBD2 H22 in a OBD1 civic question?
hey guys I'll be putting in a OBD2 H22a4 in my friends 93 EG hb dx, now I know that we wont be able to use the distri or injectors, what distrivutor could I use? a Accord maybe? or should I just get a 94 usdm H22 distributor? as far as injectors could I just use accord injectors? I doing as much research as I can before I do this so any help or pointers will be appreciated thanks TIA
Re: H22 guys.. OBD2 H22 in a OBD1 civic question? (fastwanabe)
I really dont see a problem here. Basically from what I see. Between OBD1 & OBD2 isnt the engine, its the emissions control on the car. The only thing you *might* have to do is rewire the dist. to external coil, but it really is easier than you think. Also the injectors will work all the same *you need to take out the injector resistor though.*
Edit: If you use a p28 or p72 to run the car then you wont have to wire EGR, or IAB. But you will have to wire Vtec & Vtec oil press.(of course you knew that)
Good luck
Mark
Good luck
Mark
Re: H22 guys.. OBD2 H22 in a OBD1 civic question? (SlvrEj6Dx)
I have a 98 engine with the resistor box and so far so good... All you need to do is get a 92-95 usdm distributor and also and ODB I ECU and that is that. Wire it up and your all set.
Re: H22 guys.. OBD2 H22 in a OBD1 civic question? (Jason kiDD)
yeah if its a USDM h22 then by a usdm h22 distrib. but if its jap h22 then you need to use LS distrib. cause usdm is external coil wire ..jdm is internal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I have a 98 engine with the resistor box and so far so good... All you need to do is get a 92-95 usdm distributor and also and ODB I ECU and that is that. Wire it up and your all set.</TD></TR></TABLE>
Dude. You dont have to buy another dist. and you dont have to do **** to the one you got. Just go ahead an rewire the harness. Dont go out and buy another dist. thats the same as the one you already have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlvrEj6Dx »</TD></TR><TR><TD CLASS="quote">
Just re-pin the distributor to the 2 style plug using the Civic's distributor plugs. For the injectors, I would also use the OBD2 injectors just convert the plug using the prelude injector plugs (which you have to do anyway).
I have done this with an OBD1 engine in an OBD2 car converting to OBD1 using the EK harness.
I have the wire colors to switch between the two, I just can't find my damn diagram I made. I'll get the colors again though if you don't find the info.
Re: H22 guys.. OBD2 H22 in a OBD1 civic question? (poison)
keep it coming guys I need all info I can get.
Poison if you have that diagrham please email to me.... thats for all your help guys!!.
so basically I can use the OBD2 distributor with a OBD1 p13? as long as I rewire it for 2 plug? are the colors the same on the civic harness? injectors are plug and play as long as I dont use the resistor box, correct? as far as injectors I can leave the stock DX harness as it sits just change the plugs right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">so basically I can use the OBD2 distributor with a OBD1 p13? as long as I rewire it for 2 plug? are the colors the same on the civic harness? injectors are plug and play as long as I dont use the resistor box, correct? as far as injectors I can leave the stock DX harness as it sits just change the plugs right?</TD></TR></TABLE>
I wish I could tell you yes about the wire colors, but my h22 went into an EK civic (all my wire colors matched up) but I cant say the yours will...
done the swap from obd1 h22 into obd2 civic and rewired my dx harness to run obd1 dizzy and all wires matchd perfectly...also wired obd1 injectors...its really very simple..i was suprised on how honda made everything so compatible...its like they wantd us to **** with thier cars! i love it!
Re: H22 guys.. OBD2 H22 in a OBD1 civic question? (2trix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix »</TD></TR><TR><TD CLASS="quote">done the swap from obd1 h22 into obd2 civic and rewired my dx harness to run obd1 dizzy and all wires matchd perfectly...also wired obd1 injectors...its really very simple..i was suprised on how honda made everything so compatible...its like they wantd us to **** with thier cars! i love it!</TD></TR></TABLE>
Yep, most of the colors should match up, I remember a couple of them did not match, though. I have to make the diagram again since I lost the friggin paper. I'll get that to ya bro
ok I pulled the 98 H22 harness off and I was wondering what sensors are by the crank? I will have to remove those wires off the distributor harness and wire them to the crank right? colors should match right?
If you're referring to the sensor by the oil pump, that is the CKF sensor (Crankshaft Fluctuation). This is for US OBD2 motors and and is not needed in OBD1.
Just disregard that sensor when wiring for OBD1.
thank you sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">If you're referring to the sensor by the oil pump, that is the CKF sensor (Crankshaft Fluctuation). This is for US OBD2 motors and and is not needed in OBD1.
Just disregard that sensor when wiring for OBD1.</TD></TR></TABLE>
