GSR into eg question
would it be better if i used the GSR ecu or could i use a Type R ecu on the GSR. would i see any power differences at all?
Re: GSR into eg question (JDMlifestyle)
if the car is OBDII then better choice would be a harness converter + ECU.
while the ITR ecu is not bad it can benefit from upgrades as well. also try to stay away from JDM ecus they simply suck. dyno after dyno, alot less power in the low/mid-range then USDM ecus. remeber that the ITR ecus (USDM) have imoblizer function from 00-01
smkngsr
08-05-2002 05:02 PM
