h22 transmission fluid
*SEARCHED ALREADY*
Hoping someone has pictures on how to replace transmission fluid in h22a. My 3rd gear is grinding when shifted at high RPMs.. I think I will be trying some GM Synchromesh, any help would be great.
Thank You
Anthony
Thank You
Anthony
Re: h22 transmission fluid (93preludeh22)
Try this it is the same as any B-series trans
http://www.c-speedracing.com/h...d.php
Save your self the money the GM Synchromesh more than likely isn't going to help the grind. H22 trannys are notorious for high rpm grinds regular old honda mtf is just fine for a fluid change. just my 2 cents
Re: h22 transmission fluid (double)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by double »</TD></TR><TR><TD CLASS="quote">Save your self the money the GM Synchromesh more than likely isn't going to help the grind. H22 trannys are notorious for high rpm grinds regular old honda mtf is just fine for a fluid change. just my 2 cents</TD></TR></TABLE>
Bah, honda mtf isnt all that great. I had a nasty 3rd and 5th gear grind (was running the honda brand mtf). Replaced the honda stuff with some redline and voila! No more grind in 5th and just a lil teeny grind in third but thats only at high rpm shifting. Normal daily driving there are no grinds whatsoever.
Redline all the way!!!
Re: h22 transmission fluid (AudioFuct)
shoot, i just use some pennzoil 100% synthetic 5w30 in there, same as i use in the engine. i've never had a problem with grinding or anything.. and i drive the **** out of my car too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by double »</TD></TR><TR><TD CLASS="quote">Try this it is the same as any B-series trans
OOPS didn't notice this, thanks !
change, compatible, fluid, grind, grinds, h22, helps, honda, mtf, notorious, prelude, synchromesh, tranny, transmission, type
