Jumpered Wire?? What Is it
I just purchased a 1992 Honda Civic Si. It has a B16a swap with a Turbo.. (stats are at http://www.binaryinc.org/honda/)
Anyways, I noticed something when I was going over the car.
It is a jumpered wire located on the passenger side of the vehicle right on top of the tranny and right near the water hoses to the heater core.
Any idea what this is? Why Would it be Jumpered??
Thanks in advance
Thanks in advance
Re: Jumpered Wire?? What Is it (ShoGinn)
Does the car have a aftermarket tach? It you do its a signal wire for your tach, check if the wire is connected to the blue wire on the dizzy! Can't tell due to pic to far left, try to take a better pic of the dizzy and wire.
Re: Jumpered Wire?? What Is it (Force-Fed Crx)
it connects to the coolant temp switch. after further investigation.
Im guessing according to the helms manual it is a switch that turns on the coolant relay to turn on the fan.
Right now it doesnt work, I hear the relay clicking when I jumper it on and off but the fan does not turn on.
Fan is hardwired to run all the time right now so i'll do more checking to see whats up.
Modified by ShoGinn at 7:30 AM 9/30/2004
