Code 22 at high rpms?
Old Sep 25, 2004 | 11:35 PM
Brakiss's Avatar
Default Code 22 at high rpms?
I have had my h22 in my accord for about 6 months and the only cel i get is when i am in 3rd/4th gear at high rpms. I get a cel and it says code 22 which is vtec, but vtec engages fine. I have an accord tranny so it is long geared so i take a while to shift through the gears. It only happens when i am on it and shifting high. any help?
Old Sep 26, 2004 | 02:02 AM
Root79's Avatar
Default Re: Code 22 at high rpms? (Brakiss)
The code displaying exactly in that moment wnen VTEC must torn on?
When you last time change oil?
Try to ring thrue the wiring, if there is everything OK. And check the VTEC presure swich. This sensor must be in green color.
Old Sep 26, 2004 | 10:47 AM
Brakiss's Avatar
Default Re: Code 22 at high rpms? (Root79)
no after i have engagment at 5000 and cel turns on at like 6500-7000
I changed my oil 2 weeks ago
Old Sep 26, 2004 | 02:27 PM
Turbogixxer's Avatar
clean your Vtec solenoid out (the srceen).
Old Sep 26, 2004 | 03:12 PM
Brakiss's Avatar
ill do that later tonight
Old Sep 29, 2004 | 11:16 PM
Brakiss's Avatar
Default Re: (Brakiss)
ok so i cleaned my filter, now i did some testing tonight, and it only comes on when i hit 90 mph and in 3rd or 4th at high rpms (6500+)
Old Sep 30, 2004 | 05:50 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brakiss &raquo;</TD></TR><TR><TD CLASS="quote">ok so i cleaned my filter, now i did some testing tonight, and it only comes on when i hit 90 mph and in 3rd or 4th at high rpms (6500+)</TD></TR></TABLE>
Stop driving that fast? Don't worry about it?
Old Sep 30, 2004 | 10:56 AM
Brakiss's Avatar
Default Re: (DarkKnight[DMD])
you an idiot.
Old Sep 30, 2004 | 11:43 AM
Run a light for VTec in side the cabin and see if it losing power to the solenoid at that time.
Old Sep 30, 2004 | 12:45 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brakiss &raquo;</TD></TR><TR><TD CLASS="quote">you an idiot.</TD></TR></TABLE>
You're a ***. And that was a joke.
Old Sep 30, 2004 | 09:17 PM
Brakiss's Avatar
ok on my VAFC VTi is turning off at around 85 and 6900 in 3rd, CEL turns on, and VTi wont come back till i restart the car, but VTo still hits. hmmmm?
Old Oct 4, 2004 | 03:14 PM
Brakiss's Avatar
somebody?
Old Oct 5, 2004 | 03:59 PM
ViXoN Hatch94's Avatar
i have the same problem on my 94 hatch... B16a swap. after 3rd gear, my cel comes on and gives me code 22. but the difference is my vtec wont work for some reason(new solenoid and switch,oil is fine)... i think i have to make a ground wire to the D6 pinout on my ecu to fix the problem.
Old Oct 5, 2004 | 04:09 PM
slpycd7's Avatar
I had the same problem a couple months earlier, I would drive around for a while, then hit vtec and only get a 6500 rpm redline. I thought changing my oil would help and it still didn't. So I ended up taking off the vtec solenoid and cleaning it with some brake cleaner, there are two little screens that sometimes get gummed up. That ended up fixing my problem. If that doesn't fix it, the only other way is to get another solenoid.
Playa_FL
Nov 14, 2007 10:35 AM
four o two
Feb 5, 2006 11:29 AM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
ninety9ex
Jan 26, 2004 07:40 PM
Hondasaurs
Apr 25, 2003 07:30 PM
