90 integra axles didnt fit my 1990 b16 crx.. what does?
90 integra axles didnt fit my 1990 b16 crx.. what car does?
just curious even though problems solved....wound up rebuilding the axles originally swapped in with the motor, the drivers side of the integra axle was slightly to short and the cv would bind and vibrate like crazy on lefts, and ride smooth on rights... i have hasport mounts.. if that makes any difference
Re: 90 integra axles didnt fit my 1990 b16 crx.. what car does? (thatbluecrx)
make sure you have the correct intermediate shaft to use the 90-teg axles. there is a difference between the sir and the xsi/90-93 teg ones.
Re: 90 integra axles didnt fit my 1990 b16 crx.. what car does? (photec3)
you can use either a 86-89 teg axle on drivers side with a 90-teg passenger or you can mod the drivers axle to use a teg inner joint and 86-89 shaft and outer joint. this what you do on a 88-91 civic but a eg should work. if you get the xsi int shaft then use the 90-93 teg axles for both sides.
Re: 90 integra axles didnt fit my 1990 b16 crx.. what car does? (smart monkey)
im almost positive i have an intermediate shaft... 90 integs didnt work on drivers side...
Check the casting number on the intermediate shaft.. If it is an SK7 shaft, you *may* be able to get away with using the 90-93 Integra left hand axle if you remove the metal rings from the back side of the hubs, and the rubber coated ring on the integra outer joint.. If you have the SH3 intermediate shaft, you're better off buying a custom axle..
Re: 90 integra axles didnt fit my 1990 b16 crx.. what car does? (locash)
ok, all this info is confusing. what works, and wont bind up. whats an intermidiate shaft or what ever? im doin the b16 in my CRX and the axles are confusing the hell out of me.
Re: 90 integra axles didnt fit my 1990 b16 crx.. what car does? (pogiTSI)
The intermediate shaft is basically an extension that evens the length of the cv axles on certain honda models. Any B-series swap is going to require that you get an intermediate shaft.
type Gendy
13
02-03-2003 10:51 PM
mobrep
08-29-2002 03:06 PM
