Banjo size on fuel line.
Banjo size on fuel line. NOT BOLT.
OK, i've searched and searched everyone for an answer to this. I have an h22a7 which is the type r motor. i'm making a custom fuel line, and no one seems to know what the diameter of the banjo fitting is that connects to the fuel rail. It is not 12mm. it is definately larger than that of the 92-95 prelude motors that everyone is using to swap with. and i'm not talking about the part that connects to the hose, i'm talking about the ring that goes around the bolt on the FPR on the fuel rail.
setup
DC2 Integra
h22a7 ACCORD TYPE R
Accord Type R axles w/ integra LS splines. i custom made myself.
custom 2.5" exhaust piping
ACT clutch
ACT flywheel
AEM cam gears
Progress Suspension CS1 Coilovers
Progress Suspension 25mm rear swaybar
setup
DC2 Integra
h22a7 ACCORD TYPE R
ACT clutch
ACT flywheel
AEM cam gears
Re: Banjo size on fuel line. NOT BOLT. (zeejermons)
I think that you will find that it doesn't matter. The reason I say this is that I'd bet that the company that builds the hose for you will re-use your old banjo fitting and solder on an adapter so that you can use standard SN fittiings.
Wes
Wes
Nextelbuddy
01-30-2004 07:56 AM
