wire question for swapping a b16sirII into a 93 civic ex
Old 09-19-2004, 10:27 AM
ablack934doorcivic's Avatar
Default wire question for swapping a b16sirII into a 93 civic ex
i have a green plug near the distributor left with no where to plug it on the new jdm motor what should i do with this plug. do i need to wire these up.
Old 09-19-2004, 01:53 PM
Ransom's Avatar
Default Re: wire question for swapping a b16sirII into a 93 civic ex (ablack934doorcivic)
if you are using the ex harness..that should plug into your vtec solinoid.
Old 09-19-2004, 02:54 PM
Default Re: wire question for swapping a b16sirII into a 93 civic ex (LudeSH)
the jdm motor dosen't have the solonoid on it i was wondering if i needed it or not because i am using a jdm p30 ecu
Old 09-19-2004, 05:11 PM
Ransom's Avatar
WTF...my friend has a sir2 b16 and he has a vtec solinoid
Old 09-19-2004, 05:22 PM
sorry i have a solenoid but there is no vtec pressure switch on my b16 i don't know what to do with the green plug that goes to that pressure switch
Old 09-20-2004, 01:15 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">sorry i have a solenoid but there is no vtec pressure switch on my b16 i don't know what to do with the green plug that goes to that pressure switch</TD></TR></TABLE>
Ok, it sounds like you have a JDM OBD2 B16A engine which do not come equipped with a VTPS.
You have 2 options.
(1) easiest choice. Splice the VTPS wire with your VT solenoid wire at the ecu plug. That means splice D6 to A4, and VTEC should work and no codes for VTEC will be thrown by the ecu. If you do get a VTEC code, you might need to ground the VTPS ground wire.
(2) find any US B-series VTEC solenoid and apply it to your engine.
Old 09-20-2004, 03:18 PM
Default Re: wire question for swapping a b16sirII into a 93 civic ex (Katman)
can i use the solenoid off of my d16 to make this vtec work?
Old 09-20-2004, 04:42 PM
Ransom's Avatar
no, just get a sir2 solinoid and plug it in.
Old 09-20-2004, 04:44 PM
sorry man i'm getting tired i meant can i use the vtec pressure switch from my d16z6 on the sir2 i heard you can use a sohc one on a dohc
Old 09-22-2004, 12:53 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">sorry man i'm getting tired i meant can i use the vtec pressure switch from my d16z6 on the sir2 i heard you can use a sohc one on a dohc </TD></TR></TABLE>
actually, yes you can use a SOHC VT solenoid on a b-series VTEC engine, as long as the solenoid is from a 92-95 D16Z6 engine which you have. The thing is, the VTPS plug will be pointing towards the front of the car rather than towards the passenger side of the car ( which shouldn't be an issue ), but you *might* need to extend the VTPS wires.
Old 09-22-2004, 04:56 PM
thanks for the info it helped me alot
Old 09-23-2004, 01:11 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info it helped me alot</TD></TR></TABLE>
word
hondatuner020
03-23-2015 04:48 PM
boosted_soul_94
01-22-2006 08:22 PM
ceLtic*
05-26-2005 02:59 AM
Toadfart
01-20-2005 12:17 AM
phatrick2332
08-28-2003 06:28 AM
Quick Reply: wire question for swapping a b16sirII into a 93 civic ex
