lb for lb best honda swap
Re: (DriveSideWays)
I dont think its a dumb question. Plus, im only a newb on this board, I post on about 4 others and they dont have problems sharing an educated opinion. If you dont have one, dont respond.
Re: (TurboCustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DriveSideWays »</TD></TR><TR><TD CLASS="quote">noobie is tryin to trick us into anwsering a dumb question... search function will anwser that!!!! SEARCH</TD></TR></TABLE>
You're the reason h-t sucks sometimes. Shut up and try to help out.
Welcome to the board TurboCustomZ, and I would say the best bang for the buck swap would be a b20 shortblock w/ stock sleeves, high comp pistons, stock b16 head with cams. I keep seeing people make ~200/150 whp/trq with this setup and it's dirt cheap and will last a year.
Re: (chad174)
i would say a $500 crx 6-$800 b18a, 4-$600 b16 tranny a $250 light weight flywheel,$100 lightweight crank pulley a aem/iceman cai, $250 4-1 header $60 2.25 exhaust hooked up to a $20 cherry bomb this here would not be a bad set up to start out with for a daily driver then you could always put on a turbo or b16 head. thats what i would say is the best bang for the bizuk and i would also say depending on your luck that would get you down a 1/4 mile in 14-low 15's
Re: (chad174)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad174 »</TD></TR><TR><TD CLASS="quote">
Welcome to the board TurboCustomZ, and I would say the best bang for the buck swap would be a b20 shortblock w/ stock sleeves, high comp pistons, stock b16 head with cams. I keep seeing people make ~200/150 whp/trq with this setup and it's dirt cheap and will last a year.</TD></TR></TABLE>
I can put together an h22 swap w/ i/h/e that will be cheaper, require less work and dealing with shops, and last a lifetime on 91 octane.
if you wanted to do the swap yourself, i would do a b16 or b18 (a or c1 or c5) and call it a day, i think u'll be pleasantly surprised, and now days, u can get a first gen b16 for cheap
Re: (aziz93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziz93 »</TD></TR><TR><TD CLASS="quote">i would say a $500 crx 6-$800 b18a, 4-$600 b16 tranny a $250 light weight flywheel,$100 lightweight crank pulley a aem/iceman cai, $250 4-1 header $60 2.25 exhaust hooked up to a $20 cherry bomb this here would not be a bad set up to start out with for a daily driver then you could always put on a turbo or b16 head. thats what i would say is the best bang for the bizuk and i would also say depending on your luck that would get you down a 1/4 mile in 14-low 15's </TD></TR></TABLE>
i would agree with him. that is close to my setup, not only is it a bolt in smogg legal thing if your in ca but it is fast and cheap and good base to start out on
omar256hxc
12
07-14-2004 08:51 PM
