Problem with swap
Old Sep 16, 2004 | 02:23 PM
Hyb's Avatar
Hyb
Default Problem with swap
my jdm b18c1 engine is having starting problems. today, i turned it out and after about 3-4 seconds it cut off. tried to start it again and it kept rolling over. thru on jumpers and it started back up. this is my first problem with my swap. i also had a similiar problem with the old engine in my civic. but this is the first time its ever turned off then turned back off just like that. im not sure how to fix this problem, battery, starter, or the alternator? thanks for your help
Old Sep 17, 2004 | 09:19 PM
VTECVillain's Avatar
Default Re: Problem with swap (Hyb)
A few things to check:
- Check that your timing is set properly
- Jump the test harness to see if the ECU has stored any codes
- Check/test battery
- Check/test alternator and starter
- Check/test ignition switch
B1Integra
Apr 15, 2013 09:09 AM
trapperj86
Mar 23, 2008 03:05 PM
stubk20
Oct 18, 2005 06:44 AM
Tokyo_X-treme_Racer
Mar 12, 2005 09:11 AM
Ponyboy
Mar 18, 2002 07:47 PM
