H22a4 into 98 integra. Need help.
98 h22a4 odb2 into a 98 integra ls
hasport mounts
custom axles? who make them?
can i use stock prelude shiftlinkage cable?
What about wireharness? does it plug-in 98 ls engine harness or need to modify?
need your help asap. thanks
hasport mounts
Re: H22a4 into 98 integra. Need help. (lakerschamp2000)
driveshaftshop.com => choose your mounts then axles.
You have to use the prelude linkage
modify your ls to work with the h22, ie lengthen wires, add wires etc.
If you use a gsr harness instead, the vtec wires will already be there.
92HB_HB
03-31-2003 08:31 AM
