B17A swap in a 93 del sol
I just did a B17A1 swap in my 93 SI Del Sol and have a few questions that i want to clarify.
1. Is the injector on the B17A peak-hold or saturated?
2. Can I use my stock p28 ECU to start the engine?
3. Is the B17A intake manifold/TB interchangeable with B16/B18C5?
Re: B17A swap in a 93 del sol (HIStateEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">I just did a B17A1 swap in my 93 SI Del Sol and have a few questions that i want to clarify.
3. Is the B17A intake manifold/TB interchangeable with B16/B18C5?</TD></TR></TABLE>
1. Peak and hold
2. Yes
3. Yes
1. Peak and hold
2. Yes
3. Yes
actually the injectors on a B17a saturated and also if you use the stock B17a intake man you can't use a OBd1 style tbody as those have a FITV on it. you could however use a 96-teg one as those don't use a FITV. you can use the P28 to start the car.
Re: B17A swap in a 93 del sol (smart monkey)
Thank you....btw is where a fan switch on the B17A? because I have a fan switch plug but I can't find a fan switch on the thermostat housing
it is actually on the back of the block. it has two prongs sticking out. if you want to do it on the thermostat housing you need to get a housing with the sensor on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Thank you....btw is where a fan switch on the B17A? because I have a fan switch plug but I can't find a fan switch on the thermostat housing</TD></TR></TABLE>
The thermostat switch should be on the back of the block as 2 male connectors - looks like the oil sending unit except with 2 connectors instead of 1.
Re: B17A swap in a 93 del sol (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">The B17A1 injectors are OBD1 and saturated, no need for a resistor box. The thermostat switch should be on the back of the block as 2 male connectors - looks like the oil sending unit except with 2 connectors instead of 1.</TD></TR></TABLE>
NVM
NVM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">1. Is the injector on the B17A peak-hold or saturated?</TD></TR></TABLE>
OBD1 Saturated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">2. Can I use my stock p28 ECU to start the engine?</TD></TR></TABLE>
Yes you can start the engine with the P28. You can also have the ECU chipped with DOHC VTEC specs to run the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">3. Is the B17A intake manifold/TB interchangeable with B16/B18C5?</TD></TR></TABLE>
Yes you can use the B16A or ITR intake manifolds.
OBD1 Saturated
since my motor is in the car, it hard to look for the thermostat switch behind the block. Is it on the alternator side or intake side?
btw: would any b-series thermostat housing interchangable?
thanks
thanks
the switch is more on the drivers side. near the oil filter. it is the one with the two wires and it covered by a rubber boot or sleeve. you can swap out other bseries thermostat housings but the ls one is the matching one. the 94-gsr is one not to use.
OK so LS thermostat housing is the best candinate, and when I look at the fan switch I not too sure if the person who had the motor before had swap out the B17 fan switch for a newer fan switch that had OBD1 plug. There is one sensor there that I can plug the fan harness to, and it right next to the oil filter.
