Gsr camshaft fit in b16 head?
Hi people , I new here so with a hybrid engine too.
I want know if the integra gsr camshaft fit and work better in a ls/vtec
engine, the engine have b16 head.
Re: Gsr camshaft fit in b16 head? (Rednology)
GSR cams will fit the B16 head no problem. The GSR (using a P72 ECU) has a lower VTEC point than the B16 - so using a P30, chipped P28 or similar ECU with a higher VTEC point would not be beneficial with the GSR cams. Depending on your goals and the ECU you use would be a big factor. Tuning is the key with any setup, maybe the GSR cams will work for you.
Re: Gsr camshaft fit in b16 head? (my ride)
Thanks about the adviced, I have a p28 computer but a think I can find
p78 I dindt think about the computer matter. Than you people
Thump_eg94
06-19-2010 12:39 AM
