Initial impressions from my EG K24 swap...
Old 09-18-2004, 08:50 PM
fastbrakes's Avatar
Default Initial impressions from my EG K24 swap...
Well the K24 swap is finally in there and I got the suspension and tires on, put about 100 mile son it last weekend...
Locash tuned the Hondata to get a bit better idle out of it...
Here's the setup..
03 Accord K24
generic intake with K&N filter
RSX base trans, Quaife diff
195/50-15 tires Dunlop FM901
Accord stock clutch
Hasport header
5Zigen exhaust (not sure which one) with convertor
Hondata K Pro
AC system installed, needs charging but the lines are all made and fit fine. Need to wire new fan to relay...
OK first impression is that this isn't anything like the Hondas I've been driving for the past 6 years. Taking off from a stop is effortless, 1500 RPM and it will take off smoothly from a dead stop. I shift at 3k just to keep the speed reasonable as other cars are left behind. If I wind it out to 7100 things get hairy pretty fast. 1st gear is good for about 35, 2nd I'm hitting 55, 3rd close to 90. Estimated top speed is 149 with the current gearing and tires.
I can tool around all day in 3rd gear and not worry about lugging the engine if I need to speed up. I actually can take off from 3rd gear if I slip the clutch a bit!
Talk about a flexible engine powerband...can't wait to put it on the track
Old 09-18-2004, 10:54 PM
RStoR's Avatar
Default Re: Initial impressions from my EG K24 swap... (fastbrakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastbrakes &raquo;</TD></TR><TR><TD CLASS="quote">
AC system installed, needs charging but the lines are all made and fit fine. Need to wire new fan to relay...</TD></TR></TABLE>
Please elaborate on what was required to install AC. Pics would be great too. I have an interest in this swap but want to retain AC.
Old 09-19-2004, 03:43 PM
JV
Who?
JV's Avatar
Sweet.
I'd like to see some pics also.
Old 09-19-2004, 07:09 PM
SOHC4life 96's Avatar
Default Re: Initial impressions from my EG K24 swap... (JV)
What did you do for power steering? Keep it or loose it? If you kept it, what did you use for it? Parts from other cars or kits? I too am EXTREMELY interested in the K series swap (more specifically the K20A2). Congradulations on the swap man. I havent seen any bad reviews from people who have done any K series.
P.S. Any pics?
Old 09-19-2004, 08:39 PM
Andres-eh2's Avatar
i want to see this too.
Congrats BTW
Old 09-20-2004, 04:15 PM
fastbrakes's Avatar
Default Re: Initial impressions from my EG K24 swap... (RStoR)
I'll take some pics and post on my site, since I'm not sure how to upload to the H-T board...
The AC lines were a matter of figuring out which lines to start with...I used the 03 Accord compressor lines and had the fittings cut off to use a thicker wall hose. The stock 03 hoses are thin and kinked too easily. Spacing the fan forward was the next task so I used an aftermarket thinner fan and trimmed the stock fan bracket (which supports the AC condensor) to fit. It's not too pretty but it works and clears the hoses. I may trim it a bit better before I charge up the system.
I did magage to use the stock suction line from the firewall (the thin one) and snaked it around the new engine mount to a flex piece, then into the new receiver. The receiver is now in the hole on the passenger side frame rail.
I also decided to use the pressure switch in the receiver instead of the factory one on the condensor, mainly to make it cleaner.
I still need to make lower mounts for the condensor, but Hasport will be making a new lower support bar for the production kits and I'll probably wait for that...
No power steering on the VX, it doesn't need it anyway. The new fast ratio rack will be a nice addition...should have it tomorrow ...also need to make the console to cover up the steel tower for the dash mounted shifter...I really like the way the shifter falls into your hand...
Next Up...sound deadening material in hatch and doors...who cares about the 20 lbs it will add, I can tow a truck now
Old 09-20-2004, 04:30 PM
racerus's Avatar
I want to see some track numbers.
Old 09-20-2004, 08:56 PM
Andres-eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastbrakes &raquo;</TD></TR><TR><TD CLASS="quote">I'll take some pics and post on my site, since I'm not sure how to upload to the H-T board...
host them and place then ["img]http://placeurlhere["/img] but remove quotation marks
Old 09-21-2004, 12:54 AM
Wazup's Avatar
what kind of suspension do you have?
Old 09-21-2004, 07:15 PM
JV
Who?
JV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">
Please elaborate on what was required to install AC. Pics would be great too. I have an interest in this swap but want to retain AC. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">Here is an EG with AC.
Notice the core support had to be clearanced to use the stock radiator and condensor.
brian g</TD></TR></TABLE>
Old 09-22-2004, 03:46 AM
93H22ACX's Avatar
nice...
any dyno numbers?
Old 09-22-2004, 06:25 AM
prelude9999's Avatar
Default Re: Initial impressions from my EG K24 swap... (93H22ACX)
That has to be an awesome combination. I drove my brother's 03 Accord and was surprised by the amount of torque it had. Plus it seemed to shift much better than older Accords. So, in a Civic, this would be a sweet motor, even if it only tops out at 160 HP.
How would you say a K24 swap compares with an H22 swap?
Old 09-22-2004, 03:00 PM
Lord Helmet's Avatar
dam makes me want to swap the b-series engine for the k24 now
Old 09-22-2004, 08:26 PM
fastbrakes's Avatar
With the generic intake, 5zigen exhaust (don't know which one, it's pretty quiet), hi flow cat, and the protoype Hasport header, it puts down 158 HP and 155 torque to the wheels.
Once I get the intake in a better configuration and change the muffler to something even quieter I'll run it again...
Old 09-23-2004, 07:09 AM
HT White Ops
ShaunRR's Avatar
Anxiously awaiting pics.
Also, are you talking about the new Quaife steering rack?
Modified by rochesterricer at 11:04 AM 9/23/2004
Old 09-23-2004, 03:30 PM
hondaZvic's Avatar
Default Re: Initial impressions from my EG K24 swap... (rochesterricer)
158/155 is pretty nice, i like it when the tq is so close to the hp,
i know those #'s will only get better too. NICE.
Old 09-23-2004, 04:42 PM
nickzed20's Avatar
Default Re: Initial impressions from my EG K24 swap... (hondaZvic)
hows the cooling on the stock radiator? pushing it? did you use an oil cooler?
Old 09-23-2004, 06:09 PM
H23vtecEG's Avatar
Default Re: Initial impressions from my EG K24 swap... (nickzed20)
my h23vtec in my eg hatch felt good first time i drove it. it was a drug still is. it picks up so fast and easier then any honda ive been in, and i have more then 20 swaps under my belt. i love driving the car and i'm sure u feel the same. congrats . i want to do the same thing as you but with some boost for a new project. watch out for it soon
Old 09-23-2004, 07:07 PM
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">Anxiously awaiting pics.
The pictures above are of his car.
Old 09-23-2004, 07:12 PM
HT White Ops
ShaunRR's Avatar
Default Re: Initial impressions from my EG K24 swap... (brian g)
Well, it looks good then.
Old 09-23-2004, 07:15 PM
fastbrakes's Avatar
I have the EG Del Sol 2 core aftermarket radiator in there, and temp so far has stayed below 1/2, although I don't have the air hooked up yet. I don't think that will place any more load on the cooling system, but it might. Once I start running it hard all the time I'll know better if I'll need to put on an oil cooler...
Old 09-23-2004, 07:18 PM
fastbrakes's Avatar
Yes the new Quaife steering rack, should be here any day....
Old 09-24-2004, 07:56 AM
HT White Ops
ShaunRR's Avatar
Any plans to take it to the track?
I'm a little curious what this thing will pull in the 1/4 mile.
Old 09-24-2004, 12:01 PM
95dxhatch's Avatar
hey Mr. Hasty, i'm the redhead kid you met at the ups center today. congrats on the swap. would love to see it around the city sometime. maybe looking into one of your brake setups soon if my college student budget allows.
Old 10-05-2004, 08:57 PM
racerus's Avatar
more info please
Quick Reply: Initial impressions from my EG K24 swap...
