running GSR motor with OBD2 computer
i just wondering what sort things i will have to changed in order to be able to run a complete gsr motor ( distributor , alternator, etc ) off a gsr and make it run on OBD2 computer , i dont have OBD1 computer and im not planning to buy it , because im running a PnP after market computer that is for OBD2 plug
thanks
Modified by Day Walker at 1:32 AM 10/1/2004
thanks
Re: running GSR motor with OBD2 computer (Day Walker)
If the engine is.........
94-95 : Get the alternator, dizzy(for a 94-95 gsr) and a 96+ oil pump.
96+: Everything will work.
Hope this helps you.
Phil
Phil
Re: running GSR motor with OBD2 computer (hondaguyef)
so basically the only thing i have to change is the oil pump ?? since all the running gears are basically gsr parts
thanks
thanks
boostmywankle
02-14-2007 02:36 PM
Prod
11-17-2002 08:34 PM
