the rear suspension of my car is under the control of satan
Old 09-22-2004, 08:21 PM
Prod's Avatar
Default the rear suspension of my car is under the control of satan
This is stopping me from finishing my swap and driving the damn car
passenger side rear suspension, trying to put my coilover in and the head to the shock bolt sheared off and the head to the lower control arm bolt sheared off...
what's everyone's favorite way of removing a bolt in this condition ? I'm thinking either drill it out or somehow cut the bushing out but it's still somewhat threaded on the other side.
to shitty bolts, and I put penetrant on them for about 3 days before I even tried to break them loose today, some grease monkey with an impact wrench prob put these on with like 200ft/lbs
Old 09-23-2004, 07:48 AM
Prod's Avatar
Default Re: the rear suspension of my car is under the control of satan (Prod)
some suggestions on the best way to get these bolts out ?
Old 09-23-2004, 11:55 AM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prod &raquo;</TD></TR><TR><TD CLASS="quote">This is stopping me from finishing my swap and driving the damn car
to shitty bolts, and I put penetrant on them for about 3 days before I even tried to break them loose today, some grease monkey with an impact wrench prob put these on with like 200ft/lbs</TD></TR></TABLE>
pm Satan and tell him to stop.
Seriously I'd just drill 'em out.
Which shock bolt broke off? The main one at the bottom that the lca bolts to?
Old 09-23-2004, 02:44 PM
Prod's Avatar
Default Re: the rear suspension of my car is under the control of satan (uncle)
the one where the lca bolts to the hub to and the bolt where the shock bolts to the lca...I'm gonna try to drill em out today but it's not looking promising.
Old 09-24-2004, 08:00 AM
underpressure02's Avatar
I had the same thing happen with dennis car. I went through 4 drill sets getting that POS bolt out. I got it out and rigged something in to get him home. Hate to tell you but most likely you will need to get a new lca. I used a center punch to get it in the middle before I went and drilled it and it still got messed up.
Old 09-24-2004, 08:32 AM
Prod's Avatar
Default Re: the rear suspension of my car is under the control of satan (underpressure02)
perfect ! i tried drilling it and it wasn't looking too promising but I'll give it one more shot...the only thing i can be happy about is the bolts holding the control arm to the car aren't frozen
soo does anyone have a rear passenger lca ?
Old 09-24-2004, 09:13 AM
did you try drilling it yet? That bolt was like grade 8. I would start drilling and bam snap the bit.
steveharrmr23
11-13-2008 03:27 PM
d15b2_T
04-20-2006 04:18 PM
Nipsey Hussle
08-04-2005 09:03 PM
thaimonkey
15
07-07-2005 10:42 AM
92-LS-Civic
Suspension & Brakes
12
04-01-2005 12:53 PM
Quick Reply: the rear suspension of my car is under the control of satan
