'tricking' the VTEC pressure switch to cure code 22?
Old Sep 18, 2004 | 07:35 PM
tinkerbell's Avatar
Default 'tricking' the VTEC pressure switch to cure code 22?
can i simply ground the sensor input to indicate sufficent oil pressure - or will this trip a code too? ie it will always be closed.
or is it a normally closed switch? and goes open when oil pressure reaches a certain point?
this is on an OBD0 PR3 ecu. so i will ground pin B5 to A4.
thanks
t..
Old Sep 19, 2004 | 04:57 PM
tinkerbell's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (tinkerbell)
bump for an answer tro the type of switch it is - normally open or normally closed?
Old Sep 19, 2004 | 05:17 PM
poison's Avatar
ground the pressure switch to the thermostat valve like stock, and splice the blu/blk wire from the pressure switch to the vtec solenoid.
Or, in otherwords, splice D6 with A4.
Old Sep 19, 2004 | 05:29 PM
tinkerbell's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (poison)
OBD0 PR3 ecu does not have a D6 as VTEC solenoid
OBD1's have it...
on the PR3 the VTP switch goes to B5 - so this should spice into the VTEC solenoid wire at A8?
so spice B5 with A8? too easy
oh - does this mean it is a normally open switch?
Old Sep 19, 2004 | 10:56 PM
tinkerbell's Avatar
anyone know for sure?
Old Sep 20, 2004 | 12:51 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tinkerbell &raquo;</TD></TR><TR><TD CLASS="quote">OBD0 PR3 ecu does not have a D6 as VTEC solenoid
OBD1's have it...
hmm...duno if this would work for OBD-0 ecu's, but wouldn't hurt trying and letting us know if it worked for you or not.
And yes, you'd splice B5 to A8 and ground the VTPS ground wire to the body of the VT solenoid somewhere.
Old Sep 20, 2004 | 01:31 AM
egLs20's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (Katman)
would it be the same for pwo??
Old Sep 20, 2004 | 01:32 AM
Katman's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (egLs20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egLs20 &raquo;</TD></TR><TR><TD CLASS="quote">would it be the same for pwo??</TD></TR></TABLE>
yup.
Old Sep 20, 2004 | 01:36 AM
tinkerbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">hmm...duno if this would work for OBD-0 ecu's, but wouldn't hurt trying and letting us know if it worked for you or not.
And yes, you'd splice B5 to A8 and ground the VTPS ground wire to the body of the VT solenoid somewhere.</TD></TR></TABLE>
yeah - have searched high and low, only OBD1 stuff has been discussed.
i will give it a go, hope i dont blow my ECU, lol!
EDIT - btw, thanks katman
Old Sep 20, 2004 | 01:39 AM
Katman's Avatar
EDIT - btw, thanks katman </TD></TR></TABLE>
w000t!!
let us know wut happens
worse thing that can happen is blowing a fuse...
Old Sep 20, 2004 | 10:24 AM
poison's Avatar
OBD1's have it...
oh snap, read too fast then
sorry t. see what happens yo. good luck.
Old Sep 20, 2004 | 01:46 PM
Blown90hatcH's Avatar
Katman is correct. You can just ground the black wire on the vtec pressure switch and tee the blue wire into the vtec solenoid. This is also the case when you run the JDM ITR with no vtec pressure switch and an OBD1 USDM ecu.
Old Sep 22, 2004 | 12:23 AM
Katman's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (Blown90hatcH)
...cool thanks for verifying this Jason
Old Sep 22, 2004 | 02:21 AM
tinkerbell's Avatar
Jason is very helpful! (not that i doubted Katman, lol!)
will be trying this this weekend...
Old Sep 22, 2004 | 04:57 AM
But Katman has the cool pics though.
Old Sep 22, 2004 | 05:17 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Katman is correct. You can just ground the black wire on the vtec pressure switch and tee the blue wire into the vtec solenoid. This is also the case when you run the JDM ITR with no vtec pressure switch and an OBD1 USDM ecu. </TD></TR></TABLE>
Yup, I'll second that. I installed an OBD2 B18C in my friend's 90 hatch using OBD0 electronics. The OBD2 ITR motor is pressure switchless so I did the pressure switch wiring bypass like I previously had done on a few OBD1 setups and it does also work with an OBD0 ECU (PR3 we used).
Old Oct 15, 2004 | 01:17 PM
brent_G's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (VTECVillain)
anyone have a pic of this. im gonna try it.
Old Oct 16, 2004 | 01:20 AM
tinkerbell's Avatar
Default Re: 'tricking' the VTEC pressure switch to cure code 22? (brent_G)
BTW - i didnt/havent tried this as the guy who i fitted the engine for blew a driveshaft and is of the road...
Old Jan 1, 2005 | 08:00 PM
hybridpatient95's Avatar
if i do this to my ecu is my vtec gonna be on all the time?? or is gonna be just like normal??? thanks alot cuz my friend is having the same problem. and were guessing its the pressure switch cuz all the wiring to the ecu is find and the sileniod clicks and stuff.. thanks!!!!!
Swap'DShuttle
10
Aug 12, 2012 02:35 AM
UDUBdriver
Engine Management and Tuning
Sep 4, 2011 07:04 AM
1SikEagle
Apr 11, 2009 01:02 PM
