H22 swap into 93 civic hatch...HELP!!!
im buying a 93 hatch with a 99 h22 in it its already mounted n everything but i need all the wiring done.....does anyone know of sites where i can order the right wiring harness or ecu or w/e i need to get this car running...if u have an more info about this swap please lemme know...thanks every1
Re: H22 swap into 93 civic hatch...HELP!!! (fastwanabe)
yea thanks but i been to hasport n they only have the stuff for a 92-95 civic to h22 for the obd1 motors n im puttin a 99 h22 (obd2) n i dont think they have that can i call n order it or sumthing?
Re: H22 swap into 93 civic hatch...HELP!!! (ZeX_CiViC14)
Contact brian g (Brian Gillispie) on here, I'm sure the guys at HASport could make you a near plug and play harness for the swap. You need to adapt a USDM EG or DC Integra harness with the proper plug changes and added wiring to the motor. If you get in touch with the right people, I'm sure someone in your area could wire it up properly. If you were close enough to me I could do it but that's not the case
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeX_CiViC14 »</TD></TR><TR><TD CLASS="quote">yea thanks but i been to hasport n they only have the stuff for a 92-95 civic to h22 for the obd1 motors n im puttin a 99 h22 (obd2) n i dont think they have that can i call n order it or sumthing?</TD></TR></TABLE>
If you have your civic's original wiring harness and the h22's harness, I'm sure i could get turbogixxer to redo the wiring for you. He's a master of h22 wiring. PM me and i will give you his contact info if you want to send it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeX_CiViC14 »</TD></TR><TR><TD CLASS="quote">im buying a 93 hatch with a 99 h22 in it its already mounted n everything but i need all the wiring done.....does anyone know of sites where i can order the right wiring harness or ecu or w/e i need to get this car running...if u have an more info about this swap please lemme know...thanks every1 </TD></TR></TABLE>
Do you plan on doing the wiring yourself or have someone do it for you?
slo_hatch
03-31-2008 04:27 PM
pcguy760
05-31-2006 05:34 PM
