Which b20 block do u use for a b20/vtec swap??
Re: Which b20 block do u use for a b20/vtec swap?? (Powered by Rowena Galam)
I believe the B20 b has a lower comp piston compared to the B20z. other than that all else is the same. I would say use the motor with more compression.
Re: Which b20 block do u use for a b20/vtec swap?? (smart monkey)
B20z for sure . There are a couple of guys on here w/ stock b20z bottom ends w/ 200+ whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">B20z for sure . There are a couple of guys on here w/ stock b20z bottom ends w/ 200+ whp.</TD></TR></TABLE>
yup, listen to this guy.
RedlinedEG
18
08-29-2022 09:57 AM
