need info- b18 into hx, o2 sensor conversion and more...
ive done a lot of searching here and hondaswap, and i cant seem to find how to re-pin the ecu harness to accept 4 wire o2 instead of the stock 5 wire. there was a way to do this, right? all i found is vx obd1 stuff, and im dealing with a obd2a b18b and an obd2a hx 5 speed harness in my hx.
Re: need info- b18 into hx, o2 sensor conversion and more... (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
Maybe this will help.
<A HREF="https://honda-tech.com/zerothread?id=587460
" TARGET="_blank">https://honda-tech.com/zerothread?id=587460
</A>
</A>
Re: need info- b18 into hx, o2 sensor conversion and more... (eda6 hb)
cool man. this will definately help when i wind up re-pinning. speakin of, what pins do i move where to make the 4 wire work???? i coulda sworn i saw something on it once, but i have no idea where it was..
Buy the obd conversion harness or get pinouts of your ecu and the ecu you plan on using.
Re: need info- b18 into hx, o2 sensor conversion and more... (eda6 hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hatch »</TD></TR><TR><TD CLASS="quote">Buy the obd conversion harness or get pinouts of your ecu and the ecu you plan on using.
i have the correct obd conversion harness and **** like that. i guess my problem is that i cant find a solution on how to re-pin the 5 wire hx harness for a 4 wire oxygen sensor. i think the closest thing ive found is the 5 wire obd1 vx harness repin, and i dont think its the same. im not very electrically inclined. i should just buy an ex harness......
happyabortion
06-25-2006 08:25 AM
