H22 shifter... HELP
Old Oct 10, 2004 | 01:05 AM
mdj_ge's Avatar
Default H22 shifter... HELP
is there a way to adjust the shifter... i have a eg/h22 and when i shift, it's seems like the cable is too tight..
Old Oct 10, 2004 | 06:47 AM
. o 69 o .'s Avatar
Default Re: H22 shifter... HELP (yangja)
did you route the cables through the firewall or through the floor?
Which shift assembly and cables do you have?
Old Oct 10, 2004 | 11:29 AM
EK22snatch
Guest
Posts: n/a
Default Re: H22 shifter... HELP (B16B)
you probably cant adjust the shifter the way youre talking about unless you take it out and move it around
Old Oct 10, 2004 | 07:16 PM
C M S's Avatar
Default Re: H22 shifter... HELP (EK22snatch)
HOW do u have the cables routed?
Old Oct 10, 2004 | 10:30 PM
mdj_ge's Avatar
Default Re: H22 shifter... HELP (1SICJDM)
i'm using the 2000 accord shift box and the euro r cables... and it is route under the car...
Old Oct 11, 2004 | 08:01 AM
C M S's Avatar
Is it over or in between the body and the sway bar?
slowpoke81
Nov 1, 2005 11:41 AM
huge230
Aug 3, 2005 08:26 PM
Lyrikz
Sep 4, 2003 06:41 AM
