can i run obd0 injectors in my obd1 car? and how do i tell what obd the injectors are?
as said in the post i cloged some injectors in my car. i got some new ones that the junkyard said was 1992 integra but i also got a distributor and it looks like its a obd0 dizzy so my question is can i run those injectors without a resistor box?
Re: can i run obd0 injectors in my obd1 car? and how do i tell what obd the injectors are? (cstay)
use a multi-meter to measure the resistence of the injector at the two pins.
if it is low (about 3-5 ohms) then they are 'peak and hold' OBD0 and require a resistor pack set up to run on obd1+ ecus.
if the resistance is high (about 10 to 12ohms) then they are 'saturated' OBD1+ and have their own internal resistors.
see here for a little more info: http://www.hondata.com/techinjectorwiring.html
t..
t..
AmauryR
11-15-2007 09:46 AM
MidoriEK4
04-27-2003 09:49 PM
