Alternator Clearance with a B18C5 in a CRX
I got my car back from the shop today after messing it up and the alternator pulley is still rubbing on the frame.
Now I have one of three options:
1)Pull out the alternator and hammer out that spot about a half inch
2)Cut a small gap out for the alternator pulley (afraid this might weaken the frame)
3)Find a smaller alternator
Suggestions?
Suggestions?
Yah I called them up and they said I was supposed to, and I had, I guess just not enough. Looks like I'm going to have to take off the alternator and hammer it a little more. Do you think I could just cut a notch instead?
Re: (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote">Half inch of hammering seems like alot to me. We only did about 1/4 of inch and the clearence was fine. Option 1 is the way to go </TD></TR></TABLE>
Well I got in a wreck that shifted the engine a wee bit, so I'll need a half inch
Re: (rhetorical)
just get you a good 5lb shop hammer and swing away I have more than 1inch of clearnce with my b16 crx si. If you look in my engine bay you cant even tell it was hammerd in just take your time and make it look good. just my 2 cents worth
Re: (sullenht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sullenht »</TD></TR><TR><TD CLASS="quote">just get you a good 5lb shop hammer and swing away I have more than 1inch of clearnce with my b16 crx si. If you look in my engine bay you cant even tell it was hammerd in just take your time and make it look good. just my 2 cents worth </TD></TR></TABLE>
I'm pretty sure the b16's alternator is smaller
92eg_b16
01-31-2008 08:15 PM
EKCivicR
03-28-2004 05:58 PM
