B18a1 & B18A1 Is There A Difference?
Old Oct 12, 2004 | 02:23 AM
Vtec92Civic's Avatar
Default B18a1 & B18A1 Is There A Difference?
Is there a difference between the a1 & A1 motors? Does one require a different ECU or anything like that, or is it just the way someone says it like some people use the smaller lower case letter and some people use the upper case letter? Just trying o make sure that I got the right ecu and all running with my motor as I got a few minor issues.
Old Oct 12, 2004 | 03:38 AM
hondaguyef's Avatar
Default Re: B18a1 & B18A1 Is There A Difference? (Vtec92Civic)
Just a preference of someone using caps or not.
Old Oct 12, 2004 | 07:05 AM
dohcdelsol93's Avatar
there are differences in the b18a engines between 90-91 and 92-93 integra. the earlier is 130 hp and obd0 the later is 140 hp and obd1. and the caps usage
Old Oct 12, 2004 | 08:55 AM
Default Re: B18a1 & B18A1 Is There A Difference? (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">there are differences in the b18a engines between 90-91 and 92-93 integra. the earlier is 130 hp and obd0 the later is 140 hp and obd1. and the caps usage</TD></TR></TABLE>
excellent man, thanks so I got a B18A1 so it's obd1 then . . . . what ecu should I be running to make sure that the motor runs like stock a p74 or p75?
Old Oct 12, 2004 | 09:50 AM
an obdI p75 or p74, either one will work
Old Oct 12, 2004 | 10:06 PM
sweet! thanks for the info.
Old Oct 13, 2004 | 07:37 AM
remember to verify you engine odb because if you put the wrong obd ecu you will have problems. the injectors, ecu, dizzy all have to match
Old Oct 13, 2004 | 09:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">remember to verify you engine odb because if you put the wrong obd ecu you will have problems. the injectors, ecu, dizzy all have to match</TD></TR></TABLE>
yeah I hear that . . . . i'll check with my friend to make sure that everything is what it is suppose to be. I'm pretty sure it's all obd1 though, but just the rule that out I will def. double check.
spikey0123
Dec 28, 2011 05:24 PM
Jedi Jake
May 2, 2007 04:59 PM
som1_2race
May 30, 2005 05:13 PM
Eggman
Jun 13, 2002 08:56 AM
