Knock sensor LS-VTEC (searched)
Old Oct 10, 2004 | 12:19 AM
RuthlessEF-9's Avatar
Default Knock sensor LS-VTEC (searched)
I 've searched and many of the topics covering this arent really clear or specific.
what I'm trying to find out is that is how and where would the knock sensor go on a B18 block and is it necessary? also what ecu is most commonly used on an LSVTEC swap
Old Oct 10, 2004 | 09:00 PM
vtecn8ive's Avatar
Default Re: Knock sensor LS-VTEC (RuthlessEF-9)
I'm curious also.
Old Oct 11, 2004 | 12:03 AM
bump for the late night/early ht gurus
Old Oct 11, 2004 | 09:23 AM
smart monkey's Avatar
there is no spot for the knock on the ls motor. you can drill and tap but to me not worth it. I would just use a P28 and use a good chip program or go hondata and custom tune for the motor.
Old Oct 11, 2004 | 11:51 AM
Default Re: Knock sensor LS-VTEC (smart monkey)
thats what i was thinking as well but.... bump for more opinons please
Old Oct 11, 2004 | 08:32 PM
acy76's Avatar
I welded a nut onto the upper alternator bracket bolt (the one that threads into a casting that is very similar to the knock sensor casting on the vtec blocks) and am going to use that sensor location w/ a J&S Safeguard. Here is a photo from c-speedracing.com:
They recommend you retap the threads, but I think welding a nut on is a better option. Mr. Safeguard himself recommended the weld-on method, for what it's worth.
It's been debated quite a bit, but if you're just thinking about running a stock knock board you might want to skip it altogether.
Old Oct 11, 2004 | 08:46 PM
mr.beeks's Avatar
Default Re: Knock sensor LS-VTEC (acy76)
http://www.c-speedracing.com
shows you step by step on how to do the
ls/vtec conversion
Old Oct 12, 2004 | 11:54 AM
thanks guys
1sikhatch
Aug 17, 2010 08:20 AM
Syndacate
Jul 17, 2006 12:32 AM
KURUPTinc
Jun 22, 2005 11:03 PM
vtec94civic
Nov 14, 2004 09:21 PM
Dragger817
May 22, 2003 11:54 AM
