OBD1 to OBD0 conv. Harness ??????
OBD0 to OBD1 conv. Harness ??????
I Just odered a b18c1 gsr motor for my 1991 Integra. I was wondring when i go to wire it do i just plug the jumpers to my harness and the ecu and be done or do i have to do any pinouts with my harness plugs. i hope someone understands what i am trying to ask.
Re: OBD0 to OBD1 conv. Harness ?????? (teg4life)
if you get a jumper it should have the wires for the O2,knock,IAB,vtec and vtec oil pressure. you just have to run them into the engine bay and connect to the sensors. you will also have to either repin the dist plug to use the OBD1 dist or buy a jumper for that for plug and play. I can get you jumpers for around 150.00 and dist jumpers for around 40.00.
91efbluehatch
07-28-2012 12:23 AM
KevronsEG
11
06-28-2002 09:23 AM
