CRX h22 ECU question??
I have a h22 which im currently putting into a CRX (1989 shape). The cars wiring is OBD0 at the moment and I already have a socketed PP5 ECU which I was using on my D series turbo setup, is it ok to use this with the h22a OBD1 engine?
Or best go with the P13?
Thanks in advance
Thanks in advance
Re: CRX h22 ECU question?? (djnikko)
you can use a pr3 or a pwo, and a true jdm zc distributor will bolt up to an h22a head not many people know that, so that way you can leave it obdo just to get it runnung or until you convert it.
Re: CRX h22 ECU question?? (per4mance)
get the jumper wire for obd1 conversion.best way to do it<<
honda connection
5511 mission st.
sf,ca.94112
4155871079
used/new/rebuild honda parts
honda connection
5511 mission st.
sf,ca.94112
4155871079
if you decide to convert to OBD1 and are in need of a JDM P13 ecu, I have a few for sale (reprogrammed). Hit me up if you're interested.
Re: CRX h22 ECU question?? (K@man)
Thanks for the replies guys, where can i get a jumper wire to convert to OBD1?
I checked out PR3 & PR0 ECU's and they were OBD1, is there any OBD0 ECUs I can use for the swap and just solder the wires together from the h22 harness and the d16 harness?
It sounds like my easiest method is converting the wiring to OBD1...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko »</TD></TR><TR><TD CLASS="quote">Thanks for the replies guys, where can i get a jumper wire to convert to OBD1?
It sounds like my easiest method is converting the wiring to OBD1...</TD></TR></TABLE>
there's actually no such thing as an OBD1 PW0 ecu. I can sell you an OBD0-OBD1 jumper harness if you'd like (check out my ecu site in my sig).
