Question for VA H-Ters w/ swaps
I tried searching VA's Motor Vehicle Dept. website (http://leg1.state.va.us/000/reg/TOC19030.HTM#C0070), filing through regulations as far as what will pass/fail inspection. I couldn't seem to find, however, anything on engine swap legallity.
So, anyone in VA with an engine swap wanna help me out? I just need to know what is and isn't legal. As far as I know, if the engine is the same year or newer, you can do it, but i'm sure there's far more regulations than that. I'm just making sure I have all my **** squared away when it comes time to swap. Thanks.
Re: Question for VA H-Ters w/ swaps (EH3Kid85)
as far as i know the main thing is that it a same year or newer motor like you said try calling the place you get your inspection done at and see what they say
Re: Question for VA H-Ters w/ swaps (98-integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-integra »</TD></TR><TR><TD CLASS="quote">as far as i know the main thing is that it a same year or newer motor like you said try calling the place you get your inspection done at and see what they say</TD></TR></TABLE>
Good idea. I'm heading back home to NoVA this weekend, so i'll drop in and ask.
Anyone else have any more info to throw into the pot?
im also going to be doing a swap soon so i called around and every shop i called said the samething it will past aslong as its a motor from the same year or newer and that all of the emissions stuff is hooked up
In VA you shouldn't have to worry about anything! I have had swapped cars for years and have never been questioned once! Its not even a requirement for a state inspection! The only thing Va requires is that you have a catalytic convertor and that doesnt even matter if you know someone!
Guest
Posts: n/a
Re: Question for VA H-Ters w/ swaps (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">In VA you shouldn't have to worry about anything! I have had swapped cars for years and have never been questioned once! Its not even a requirement for a state inspection! The only thing Va requires is that you have a catalytic convertor and that doesnt even matter if you know someone!</TD></TR></TABLE>
I second that. and I even gut my cat on every car. glad we dont have emissions in the lower part of the state
grizzman
32
06-01-2007 10:10 AM
mustang5.slow
11
05-01-2007 09:25 PM
