b16a2 in eg what power steering hose?
I have a 2000 b16a2 usdm si engine in my 95 eg...I used the b16a2 power steering pump and highpressure line when i did the swap, but had to bend the line a good bit to make it fit the rack, well with all this bending and the motor moving back and forth the hose has broken at one of the bends...does anyone know of a hose that is a direct bolt on to the eg rack and the si pump....if so please let me know, If did some minor mods to work also please let me know.
Re: b16a2 in eg what power steering hose? (forcefedish)
well i have a 92EG with a B16a3 and i don't need the P.S. you don't need it. it's only for losers... I hate P.S. it sucks. if i were you i wouldn't use it. Just plug in everything but cut or don't use the belt. that what i do... any ? halla at meeh...
Re: b16a2 in eg what power steering hose? (92_EGhatch)
yeah ps is not that big of deal but if you want it keep it. if you want to take out I would not just disconnect the hose. the ps rack and manual are different in ratio. I would at least go get a manual rack and swap out.
bonbon
04-10-2004 02:19 PM
