b20vtec
Old Oct 6, 2004 | 08:14 AM
importlegions's Avatar
Default b20vtec
i plan on getting a b16 head, i heard that the valves will nick the pistons of the b20? if so, where can u get pistons that will not nick the valves, and can u use the bottom end of the b20?
Old Oct 6, 2004 | 05:47 PM
chad's Avatar
Moderator
Default Re: b20vtec (importlegions)
where do peope get these lies........no the valves will NOT nick the pistons with stock cams....
Old Oct 6, 2004 | 06:25 PM
CWestAccord's Avatar
Default Re: b20vtec (chad)
/\ truth. WTF gave you that impression, unless the head has been milled like hell.
Old Oct 18, 2004 | 08:00 AM
Default Re: b20vtec (CWestAccord)
handlesbarfar (cc member, and ht member) said there was no way around that, hes pretty fuking smart tho.
Old Oct 18, 2004 | 08:01 AM
will the stock internals be able to handle the higher revline or was he mistaken when he said i had to get that fixed to, if i got a vtec controller and only let it rev to 7200, would that be a safe fix?
Old Oct 18, 2004 | 08:13 AM
(cwestacord) just read ur sig, with the linkin park song, i had that song stuck in my head for like a month ,and now it sback haha
Old Oct 21, 2004 | 08:09 AM
clint g's Avatar
Ok I will set u all straight there is not much clearance between the valves and pistons so dont advance or retard the timing to much and stock gsr cams will nick the pistons so have a machince shop make the valve relief bigger or get new pistons and the b20 block cant be ran 2 hard it can only withstand 6000rpm u have to change the rod bolts to some out of a gsr or engine built to wind in the 8500 range this is from my experience so be careful and do it right
jdmlover.dc4
Aug 6, 2012 02:27 AM
crazi92hb
79
Aug 9, 2011 09:47 PM
quick Dick
Mar 30, 2008 02:00 PM
BigBlockCRX
Apr 19, 2005 11:15 AM
Ri5e
Feb 13, 2002 07:03 AM
