H22 hesitation @ about 2200-3000 rpm's
Location: In the heart of the ghetto of the, Suburbs NYC
This is my second hybrid project that i have come across with some hesitation on the low end @ around 25-2900 rpm's.
Is this a common issue or is there something wrong with my setup...new plugs/cap/wire/rotor..all you can think of for a full and new basic tune-up is done to it...any ideas?
Re: H22 hesitation @ about 2200-3000 rpm's (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]Timing.</TD></TR></TABLE>
Re: H22 hesitation @ about 2200-3000 rpm's (hondaZvic)
I would suggest you replace your 02 sensor, I had that happen to me and it was fixed by replacing my o2
Timing is perfect.
Checked with timing gun and that checked out ok.
The o2 sensor i didn';t try...would that be a factor even though it doesn't throw any CEL's?
But it's def only happening at 25-3000 rpm's in any gear...happened this morning in 5th gear
Re: (92hybridAccord)
o2 affects the timing. When it happened to me it would feel like the timing is being pulled, you wont get a CEL either. Dont buy that bosch universal crap, I went through four before I bought a stock one and wala no more hesitation. hell if you have the stock accord or civic one then use that.
Re: (accord387)
It does hesitate on stomping on it as well as cruising.
Also i'll try the o2 sensor this weekend and update..thx
89 CRX SI
04-22-2003 04:21 PM
