h22a axles in 99 civic
Old 10-03-2004, 03:57 PM
WhItE99CiViC's Avatar
Default h22a axles in 99 civic
was wondering what kind of axels or spindles i need to use to make them fit. Today i started to put the axels in and the splines are diffrent on the outter hubs
Old 10-04-2004, 12:48 AM
i_eat_ROCKS's Avatar
Default Re: h22a axles in 99 civic (WhItE99CiViC)
what mounting kit are you using?
my setup are 94 integra front disk brakes with Raxles axles. Ive been using these axles for a while now they ride like a champ, just as if i had i still had my sohc motor inside rides smooothly. but the only thing you cant SLAMM your car to the ground. i had to lift my car around 1 - 2 inches but my car was slammed tires were fully tucked. you can go to the webpage for raxles. and talk to the guy marty. he helped me alot!
i have the exact same set-up as you i think. white 99 civic ex coupe h22 motor swap.
Old 10-04-2004, 05:54 AM
Adam.'s Avatar
http://www.driveshaftshop.com
http://www.raxles.com
http://www.hasport.com
Old 10-05-2004, 07:51 PM
Default Re: h22a axles in 99 civic (DarkKnight[DMD])
thanks for all your help i wound up getting them from hasport
Old 10-05-2004, 07:54 PM
. o 69 o .'s Avatar
Gator Axles are also really good. They make them for custom applications such as h22 swap and are actually more reasonable then some of the other alternatives
Old 10-07-2004, 02:04 PM
EK22snatch
Guest
Posts: n/a
Default Re: h22a axles in 99 civic (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">Gator Axles are also really good. They make them for custom applications such as h22 swap and are actually more reasonable then some of the other alternatives</TD></TR></TABLE>
very true, but Stan from fast-turbo.com is horrible to work with. took me like 4 months to get my axles from when i paid for em!
Old 10-07-2004, 05:06 PM
. o 69 o .'s Avatar
Default Re: h22a axles in 99 civic (EK22snatch)
how have they held up though ?
Old 10-08-2004, 08:44 AM
EK22snatch
Guest
Posts: n/a
well, teh 12.4 miles ive put on em seem to be okay, but theres some moving noise though, but i think it might be something with teh brakes cuz i installed new pads
corkss
09-10-2008 11:00 PM
dutchman5
10-04-2006 04:07 AM
turbo95eg6
02-14-2006 01:26 PM
turbo95eg6
02-13-2006 06:58 PM
eL
01-15-2005 08:20 AM
Quick Reply: h22a axles in 99 civic
