Idle Surge Problem on my H22 EG---please help!!!!
Location: In the heart of the ghetto of the, Suburbs NYC
OK, pics are courtesy of fastwannbe...
{{{{{{{IMAGE IS SMALL BUT I'M SURE WE CAN ALL RESIZE TO READ CAPTION, THX...AS I AM AT WORK AND NOT AVAILABLE TO EDIT PICS}}}}}}}}
I tried to copy as much but i am still surging...here are the pics with what i have.
Only thing different with my car is that it is a VX so i have the EGR there, but no connected with a vacum to the IM....still throws a CEL 12 though.
The lst pic is what i recently did, as i did have the egr vacum plugged up to IM prior to last week
Re: Idle Surge Problem on my H22 EG---please help!!!! (92hybridAccord)
Seriously sounds like a wiring problem to me. And if your EGR is plugged in and you are still getting a code then obviously something isnt right..
Re: Idle Surge Problem on my H22 EG---please help!!!! (Jason kiDD)
so c'mon homie...come over to the shop, you're back in nyc right?
First day of work is today at the new location. So its gonna take me a few days to get situated. I will holla at you on the celly once I am back to normal..
hey you did adjust the nylon screw inside the FIV right? that that thing under the throttle bodythats got coolant hoses going into it.
Re: Idle Surge Problem on my H22 EG---please help!!!! (fastwanabe)
i didn't check that, but i will try and adjust today after work when i get to the shop..oh yeah, i got the 02 sensor also, so i will update you on that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hybridAccord »</TD></TR><TR><TD CLASS="quote">Only thing different with my car is that it is a VX so i have the EGR there, but no connected with a vacum to the IM....still throws a CEL 12 though. The lst pic is what i recently did, as i did have the egr vacum plugged up to IM prior to last week </TD></TR></TABLE>
You have the EGR lift valve solenoid hooked up and wired up? Code 12 is just saying that the EGR lift vavle is not the same opening as what the ECU wants it to be.
ranta18
01-21-2005 09:23 PM
