b18c1 1989 crx hf couple of problems Idles good but tryign to drive it dies/ fan wont come on
K here my problems see if you guys can help
I have a b18c1 with a hydro conversion kit from hasport stock engine pretty much except header and intake intake manifold from skunk2. Car is converted to obd1 and is using a 94 stock gsr computer.s
1) car will idle good but if you put it in gear and try to drive it will die.
if you barely give it gas it will move around yard but i can't shift into second because once it revs a little pass 2k it dies. Will go in reverse and do same thing.
2) radiator fan isnt coming on. There are 2 coolant switchs on 94 gsr motor I think. One on head and one on back by thermostat. Nothing is plugged into back one. I have the coolant switched hooked to the one on/near head in front of motor.
3) im using map sensor from crx that is on firewall hasport said it was ok is that cause my car to bog? Car ran fine with hf motor in it and d16a6 motor in it on that map sensor.
Thanks in advance
DEF
Thanks in advance
DEF
Re: b18c1 1989 crx hf couple of problems Idles good but tryign to drive it dies/ fan wont come on (d
oh yeah it wont rev at all past like 2.5 k with out bogging even in nuetral.
DEF
DEF
its possable that 2 of your sensors by the intake might be pluged in wrong the plugs are identacle, same thing happend to my friends itr idled like **** and wouldent drive at all.
When he swaped the plugs to the proper sensores it ran and drove fine. hope this helps
im using map sensor on firewall i tried extending it to that didnt fix my problem.
DEF
DEF
got customer here last week,same problem.i found out that the tps wire was connected to the map sensor.guy did the swap put them backword.
honda connection
5511 mission st.
sf,ca.
4155871079
new/used/rebuild parts for ur honda
honda connection
5511 mission st.
sf,ca.
4155871079
fan doesnt come on because you have to wire up that switch on the thermostat housing.. the sensor on the head is a coolant temp. sensor that the computer needs to read to determine if the car is hot enough to go into closed loop. as for the map sensor, make sure the connector has a green wire in the middle. map and tps sensor plugs look the same, just the colors arent in the same place. check those out.. and tell us how things go. good luck.
car is fixed it was a minor problem thanks for all the help. I would rather not say what the problem is.
DEF
DEF
rolledthatho
02-08-2011 10:57 PM
lewsscroos_
30
04-14-2005 09:18 AM
deftones0817
34
10-24-2004 05:30 PM
deftones0817
10-14-2004 07:18 PM
