Questions of H22A4 in to 99 Civic CX, Please Help me...
I just got a 99 CX 5 speed, I got a 98 H22A4 5 speed with all the partexept the mounts, I have a couple questions, It will be great if you guys can please help me here,
1) Is the h22A4 a JDM engine or not?
2) what axles I have to use?
3) what wiring harness and ECU I have to use?
If anybody has any information please let me know, also if anyone has step by step with pics, on how to this swap, I will gratly appreciate it.... Thank you guys!!!
Re: Questions of H22A4 in to 99 Civic CX, Please Help me... (SkunkEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkEG »</TD></TR><TR><TD CLASS="quote">I just got a 99 CX 5 speed, I got a 98 H22A4 5 speed with all the partexept the mounts, I have a couple questions, It will be great if you guys can please help me here,
If anybody has any information please let me know, also if anyone has step by step with pics, on how to this swap, I will gratly appreciate it.... Thank you guys!!!</TD></TR></TABLE>
it is usdm
use hasport, placeracing or raxles axles
it is usdm
Re: Questions of H22A4 in to 99 Civic CX, Please Help me... (lakerschamp2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 »</TD></TR><TR><TD CLASS="quote">
it is usdm
use hasport, placeracing or raxles axles</TD></TR></TABLE>
cool thanks, now, what else i need besides mounts and axles, I already have a prlude shift linkage, and a 98 prelude ecu. Is it posible for this swap to work perfectly without any engine codes and if so, what ecu and harness should I use?
it is usdm
Same setup i have pretty much, works perfectly, '97 CX with '99 H22A4, hasport mounts and axles, i recommend other axles though, already twisted 2 pair i use the skunk2 OBD1 conv. harness w/ a p13 ecu and it was tuned by Payn Technologies, no codes thrown at all since the swap(June 03), be careful with that ecu that you have, some of the newer preludes came with an immobilizer that kills the ecu, thats what happened to my 99 one even though it came out of an import junkyard, not sure exactly what years though, i would think 97+.
Re: Questions of H22A4 in to 99 Civic CX, Please Help me... (CXHATCHver2.2)
Thanks a lot dude! I was wandering about that, do you think if I use the stock civic harness and a Gsr obd2 ecu it would be fine also? I just traded my 1992 civic with a GSR swap for this 99 civic hatch bone stock and Im not a big Fan of OBD2 motors I just got the H22 cause i got it for dirt cheap..
Not really sure if it the gsr ecu would work, the harnesses would be different, plus you need the h22 harness for all the correct sensor plug placements, but just get an obd2--->obd1 conversion harness and get a obd1 p13 ecu(JDM Prelude), easiest option unless you can get a good working obd2 prelude ecu, not all are "dead" like that, just ones that are actually stolen or think they were stolen supposedly, yours might work, just try it when you get the swap done, might get lucky
PhatBoy5015
33
10-29-2017 11:42 AM
baphomet
05-15-2006 06:15 AM
JDM CRX
02-20-2002 04:22 PM
