How to Tell Prop Valve Size?
B A N N E D
okay, i'm about to do a rear disk conversion on my eg with some from a jdm eg. i've been told it will be okay for me to use the 92-95 ex/si e-brake cables and 92-95 ex/si brake lines.
i went to a junkyard and picked up a 92-95 civic 15/16" brake booster and the prop valve from the same car. is the prop valve 40/40 or the 40/30 i've been reading about? or better yet, am i able to tell what size it is by some marking on the outside?
any help is appreciated. thanks.
This user can set his title.
Re: How to Tell Prop Valve Size? (vtecb20coupe)
What model 92-95 civic did you pull it from? The SI model comes with the 40/30. That is good enough as I am running that also.
I'm not sure if the EX model comes with the 40/30 or not.
Most other models like DX, CX, HX don't have the 40/30 but have the lower versions which you don't want.
Also, you have tell what you have because the PP valve marks it somewhere. You have to look carefully
B A N N E D
Re: How to Tell Prop Valve Size? (ki3t)
that's what i can't remember. i know it was a purple coupe that i pulled the booster and prop valve from, possibly an ex. i looked at all the civics in the yard and finally found the 15/16". now, if the car came with a booster that big, it should at least be a 40/30, correct?
That I'm not to sure of.. wait.. the EX coupe did not come with Rear disc so it most likely does not have the 40/30 PP. Sorry man... Check the PP you took. It tells you what you have..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki3t »</TD></TR><TR><TD CLASS="quote">That I'm not to sure of.. wait.. the EX coupe did not come with Rear disc so it most likely does not have the 40/30 PP. Sorry man... Check the PP you took. It tells you what you have..</TD></TR></TABLE>
the ex coupes do come with rear disc except it was a option. most I've seen have ABS with them.
Re: How to Tell Prop Valve Size? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv »</TD></TR><TR><TD CLASS="quote">
the ex coupes do come with rear disc except it was a option. most I've seen have ABS with them.</TD></TR></TABLE>
Thanks for clarifing
The number should be stamped in the body of the valve!
What you will NEVER be able to find out is if the numbers mean anything as to how they function!!! It would seem that the number is nothing more than a "part number".
Wes
Wes
B A N N E D
Re: How to Tell Prop Valve Size? (Wes V)
ok, so look at the valve and it tell me if it's 40/40 or at least 40/30? i need clarification before i even take mine off and get disappointed.
B A N N E D
well, i check the prop valve this weekend and couldn't find anything that would distinguish either a 40/30 or 40/40. anyone else have any useful info for me?
SoCal EJ1
Suspension & Brakes
09-17-2008 10:21 AM
Tyson
03-13-2007 06:40 PM
jdmcivicferio
03-18-2003 07:40 PM
PyroVTEC
12-17-2001 05:04 PM
