no vss would that cause limp mode?
Old 10-15-2004, 03:32 PM
deftones0817's Avatar
Default no vss would that cause limp mode?
I dont have my vss hooked up because i dont have one would that cause car to run in limp mode?
DEF
Old 10-15-2004, 03:36 PM
smart monkey's Avatar
Default Re: no vss would that cause limp mode? (deftones0817)
yes it can
Old 10-15-2004, 03:41 PM
Default Re: no vss would that cause limp mode? (smart monkey)
are you positive because ive reset timing twice now check other post. This could be my problem? Damn...
DEF
Old 10-15-2004, 03:59 PM
no vss can make the car not have vtec.
Old 10-15-2004, 04:04 PM
**** vtec i cant rev past 2.5k lol i need to find out why im in limp mode. I'm not throwing any codes.
DEF
Old 10-15-2004, 04:37 PM
so you are saying ignition timing is fine. how is fuel pressure and also how are the ignition parts?
Old 10-15-2004, 04:44 PM
fuel pressure from vafc says 42 cam timing is correct and dizzy timing is correct too. its also a brand new distributor
Old 10-15-2004, 05:12 PM
if the vss is not hooked up you should have a cel for that. this one is a bit harder to diagnose since the car is not in my face. what can you tell me about the setup and what you have done.
Old 10-15-2004, 05:47 PM
hondaZvic's Avatar
no vss will cause u to go in limp mode.
u need to replace it or hook it up or whatever.. just get it working.. with out it ur speedometer will not work (obviously), vtec will not work, and and u will have an ealier rpm cut off..
for me it was a like 6800 rpm.. or around there somewhere.
i just fixed this problem on my car.
Old 10-15-2004, 07:37 PM
RTFM
v4lu3s's Avatar
i made a 250 mile drive with no vss it sucked being stuck at less than 3k rpm the whole trip.
you NEED a vss.
Old 10-16-2004, 01:01 AM
tinkerbell's Avatar
Default Re: (v4lu3s)
soem guys here need to check their terminoligy...
VSS does NOT cause 'limp' mode.
it casues 'safe' mode.
rev limit will be 7500 and no VTEC and richer fuel.
if you are not throwing codes and cant rev past 2.5k - id say your ECU could be the problem
Old 10-16-2004, 08:58 AM
hondaZvic's Avatar
Default Re: (tinkerbell)
i always thought limp/safe were the same thing...
whats the difference?
Old 10-16-2004, 09:09 AM
Default Re: (hondaZvic)
added vsss now i can get the car up to 10 mph almost but it ******* falls on face and dies. I also added knock sensor and reset computer. Im not getting any more codes but its in limp mode still. I cant go above 2.5k rpm. Help
Old 10-16-2004, 09:24 AM
hondaZvic's Avatar
Default Re: (deftones0817)
what car is this? and what all have u done to it?
Old 10-16-2004, 09:48 AM
its a 89 crx hf with a 94 b18c1. The car was converted to obd 1 with a blown90hatch harness.
car is in limp mode and i dont know what to do now. All im getting is a code one. Oxygen sensor. Confused what to do now im getting a new oxygen sensor but i know that isnt the problem.
DEF
Old 10-16-2004, 04:46 PM
hondaguyef's Avatar
No mas Problemas! We fixed everything today.......almost
Phil
Old 10-16-2004, 05:05 PM
hondaZvic's Avatar
Default Re: (hondaguyef)
what was it?
Old 10-16-2004, 06:23 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">what was it?</TD></TR></TABLE>
Pm DEF about it. We don't want to discuss it until the "issue" is resolved. We'll let you know asap though.
Phil
Old 10-18-2004, 12:19 AM
tinkerbell's Avatar
i t h i n k y o u m i g h t h a v e a p r o b l e m w i t h y o u r E C U
try a known good one and see if the car runs.
Old 10-18-2004, 11:38 AM
hondaZvic's Avatar
they already fixed it man... it was them crappy conv. harnesses...
*i hate those things*
smokey68321
04-18-2010 05:20 PM
geezer_187
03-28-2006 08:05 PM
type Gendy
03-19-2003 11:11 AM
Quick Reply: no vss would that cause limp mode?
