SWAP!!!
Old Oct 13, 2004 | 07:22 AM
nyzpapi4u's Avatar
Default SWAP!!!
what iam trying to do is kinda crazy......from what i think.
I want to put a J30 accord engine in a 99 civic!!!
You think that is posible and how much would that cost me ??
and what would i have to take into consideration??
Old Oct 13, 2004 | 07:26 AM
handa's Avatar
Default Re: SWAP!!! (nyzpapi4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyzpapi4u &raquo;</TD></TR><TR><TD CLASS="quote">what iam trying to do is kinda crazy......from what i think.
and what would i have to take into consideration??</TD></TR></TABLE>
Definitely not do it if I were you, unless you want to be different. You are better luck with a B-series motor, much more simple and done many times.
There was a thread with this ugly civic with an ugly accord motor.
Old Oct 13, 2004 | 07:30 AM
nyzpapi4u's Avatar
Default Re: SWAP!!! (handa)
you really think its a bad idea..also i forgot to mention its a V6 motor!!!!
plus my proffesor said its very much posible!!!
JDMFreak's Avatar
with the money and effort of what your trying to do is not worth due to the fact that it would be easier and cheaper just to put in a B or a H-series motor
Old Oct 13, 2004 | 07:44 AM
AdamDavidDoyle's Avatar
Default Re: SWAP!!! (JDMFreak)
Has the V6 Accord motor in a Civic been done? I know that you will be stuck w/ Automatic Trans though... no Stick for V6 accord. the old ones anyway.
Old Oct 13, 2004 | 09:39 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: SWAP!!! (AdamDavidDoyle)
Accord V6 = 200hp
Integra Type R engine = 195hp
H22A Prelude engine = 195/200hp
The Accord V6 will require shitloads of custom fabbing to get it to work, and did you also not think that the V6 engine will have an auto tranny as well?
You'll get 200hp with the other two, with little extra work envloved over the stock engine.
Old Oct 14, 2004 | 09:18 AM
dohcdelsol93's Avatar
Default Re: SWAP!!! (B18C5-EH2)
v6 swap would be way too heavy, i'd woop up on it with a type r swap on the 1/4 mile and not sacrifice handling on the streets. Plus it's a hella lot cheaper.
Old Oct 14, 2004 | 03:04 PM
Goatsterrman's Avatar
Default Re: SWAP!!! (dohcdelsol93)
For the amount of money you will spend on doing that swap, you could do not only a B or H series motor, but you could afford to do a K-series swap. The J30 does not have near the aftermarket support you will find with a K,H, or B. And you will end with not only a faster car but a better Handling car with the K or B.
Good luck to you if you decide to do it, it will be very unique, but I think with the money you will spend you could have a much faster and more reliable car going with a different motor.
Old Oct 15, 2004 | 05:00 AM
Default Re: SWAP!!! (Goatsterrman)
Plus the 98-02 V6 Accord Auto Trannys are kinda sketchy. My wife had to have hers replaced at 75k miles. and there was recalls and stuff w/ them.
Old Oct 15, 2004 | 08:18 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Accord V6 = 200hp
You'll get 200hp with the other two, with little extra work envloved over the stock engine.</TD></TR></TABLE>
Perfect!
Exactly what I was going to respond with.
Not to mention there is little/no aftermarket support for the v6.
KellyKoning
Transmission & Drivetrain
Feb 8, 2016 10:27 AM
asbestos2001
Jan 6, 2009 01:32 PM
SpoogenJay
Feb 6, 2008 04:14 AM
Ryan kilburn
Aug 20, 2007 02:56 PM
alphanumeric
Apr 8, 2004 08:15 AM
