missing plug on throttle body
Old Oct 8, 2004 | 06:43 PM
JaymieTypeR's Avatar
Default Wiring up MAP Sensor
ok so i just finished doing my engine swap, i put a 97 type r motor into a 92 vx hatch. I saw that there was no plug to go into the one on top of the throttle body, i think its for the map sensor but im not a 100% sure. there is one for the side that faces the firewall but not one for the top.
i am assuming the is suppsoes to be one there but does anyone know what will happen if i run the car without it. or what i could do to fix this?
im going to be running it off a chipped P08 ecu.
any help appreciated
thanks
Modified by JayDM_TypeR_EG at 1:50 PM 10/9/2004
Old Oct 8, 2004 | 11:22 PM
Kendall's Avatar
You may need to run a vacuum line from the top of the throttle body to a MAP sensor that can be located elsewhere.
Old Oct 9, 2004 | 12:49 PM
Default Re: (Kendall)
ok i finished all the wiring and got the car running and its only throwing a code three, which is for the map sensor, so for sure the map sensor plug was missing.
i went and got a plug that will go into there and need to know how to wire it in.
anyone know how to wire up a stock map sensor?
its for a JDM type r running off a p08 ecu.
thanks for anyhelp
idriveahonda
Sep 22, 2011 02:06 PM
jphil101
Apr 2, 2010 11:36 AM
j-robsDA
May 31, 2005 06:48 AM
SuicideSlide
May 16, 2005 01:47 PM
Trak_Day
Aug 25, 2004 08:33 AM
