Fuel pressure help on H22/Civic!!!!
Ok I had to use a adjustable FPR from a 92 Civic, I have a B&M fuel gauge on there also. What pressure should it be set at when I am under the hood looking at the gauge? Right now in idle I am sittin at 34psi.
THANKS!
THANKS!
Re: Fuel pressure help on H22/Civic!!!! (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote"> Ok I had to use a adjustable FPR from a 92 Civic, I have a B&M fuel gauge on there also. What pressure should it be set at when I am under the hood looking at the gauge? Right now in idle I am sittin at 34psi.
THANKS!</TD></TR></TABLE>
Do you have an obdI h22 or obdII h22?
Re: Fuel pressure help on H22/Civic!!!! (93H22ACX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX »</TD></TR><TR><TD CLASS="quote">28-32psi on H22A1 pretty sure its the same for H22A4 also</TD></TR></TABLE>
Saturated = 47-54 @ WOT.
They are not the same. The saturated injectors take a bit more pressure.
Re: Fuel pressure help on H22/Civic!!!! (uncle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncle »</TD></TR><TR><TD CLASS="quote">
They are not the same. The saturated injectors take a bit more pressure.</TD></TR></TABLE>
thanks for the correction
Its a 94 H22 with a resister box, its OBD 1! What pressure at idle, I dont have a inside gauge yet only under the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote">Its a 94 H22 with a resister box, its OBD 1! What pressure at idle, I dont have a inside gauge yet only under the hood.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=685846
page 2
Modified by uncle at 8:55 AM 10/12/2004
page 2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote">somethings wrong with that link.</TD></TR></TABLE>
No there's not, check again.
So, I adjusted my FP to what it should be at. 40 at idle and 52 at WOT. Before I put FPR anf the Fuel gauge on I noticed a "flat" spot around 5k rpm and it lasted to about6k rpm. Since the fuel adjustment my car no longer has that flat spot. Its' runnin great, cant wait to get some new numbers!
Thanks for all the help HT members!....
chrisb
05-09-2005 07:06 PM
