obd2 - obd1 ls block differences??
Old Oct 11, 2004 | 06:32 AM
blackeg's Avatar
Default obd2 - obd1 ls block differences??
basically, can i use an obd1 block with an obd2 head in an obd2 car? are there any sensors or anything that are different and stuff like that?? this is for b18b1 engine. thanks
Old Oct 11, 2004 | 09:08 AM
smart monkey's Avatar
Default Re: obd2 - obd1 ls block differences?? (blackeg)
you can't unless you switch out oil pumps with a OBD2 one as the OBD2 cars and ecu look for the ckf sensor on the oil pump
Old Oct 11, 2004 | 05:48 PM
blackeg's Avatar
Default Re: obd2 - obd1 ls block differences?? (smart monkey)
ok so just the oil pump change? would this even matter if i run a jumper harness and an obd1 p75 ecu?
Old Oct 11, 2004 | 06:30 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ok so just the oil pump change? would this even matter if i run a jumper harness and an obd1 p75 ecu?</TD></TR></TABLE>
No, it wouldn't. I was going to suggest that anyway .
Phil
Old Oct 11, 2004 | 06:56 PM
blackeg's Avatar
Default Re: obd2 - obd1 ls block differences?? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
yea ive already got the obd1 ecu and conversion harness (gotta rock obd1 for the uberdata for my turbo to come ).
now this is gettin off topic from the title a little, but would i be able to use an automatic block in a 5spd? just the block here, no head, tranny,ecu or anything else
Old Oct 12, 2004 | 01:37 AM
auto block is fine to use.
Old Oct 12, 2004 | 03:12 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">auto block is fine to use.</TD></TR></TABLE>
yea ive already got the obd1 ecu and conversion harness (gotta rock obd1 for the uberdata for my turbo to come ).</TD></TR></TABLE>
DAP97SI
Mar 1, 2012 05:10 AM
EM1_00Si
Jun 10, 2007 09:01 AM
AsianMullet
Jan 22, 2005 05:21 PM
92civic_si
16
May 6, 2004 02:50 PM
Civic
Dec 14, 2003 11:51 AM
