Can I run an OBD-1 p13 ecu with my current fuel injectors??
i have an H22A4 in a 99 civic cx,
there is no resistor box so i believe i can safely assume that i am running the saturated injectors that originally came with the engine (not peak and hold injectors)
so if i got an obd1 p13 ecu, would my car run properly when the ecu thinks i have different injectors (not only different but smaller)
thanks for any help you can give me!!
Re: Can I run an OBD-1 p13 ecu with my current fuel injectors?? (fastwanabe)
That post tells me nothing (I'm already running without a resistor box, so I already know I can run without a resistor), does anyone have any knowledgable input on this?
Re: Can I run an OBD-1 p13 ecu with my current fuel injectors?? (prelude9999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude9999 »</TD></TR><TR><TD CLASS="quote">
i think ur question may not be clear.....
but... i will say this. u can use an obd1 p13 without a resistor box and h22a4 injectors.
does that help? if not? clarify ur question please.
Re: Can I run an OBD-1 p13 ecu with my current fuel injectors?? (93H22ACX)
Thanks for the help! That is what I needed to know. Though I do have a question now:
if a p13 OBD-1 ecu is designed to be used with peak and hold injectors, how can it work properly with an H22A4 engine that uses saturated injectors? and not only that but the injectors are different sizes
All your ecu does is ground the injectors when its time to fire them.
It has no idea what kind of injectors your using.
The only thing that matters is the injectors themselves.
If your using saturated injecotrs(use 12v) then no resistor box is needed.
If your using peak and hold(use approx 6-8v) then you need the resistor box to remove the extra voltage before it gets to the injector.
Re: Can I run an OBD-1 p13 ecu with my current fuel injectors?? (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">All your ecu does is ground the injectors when its time to fire them.
If your using peak and hold(use approx 6-8v) then you need the resistor box to remove the extra voltage before it gets to the injector.</TD></TR></TABLE>
yep he's right. the ecu just basically tells the inj's when to fire.
Re: Can I run an OBD-1 p13 ecu with my current fuel injectors?? (hondaZvic)
4thgenhtch
01-31-2006 12:44 PM
