help!!! type R teg motor swap into a 99 gsr..wont start
this is what i got integra gsr shell 95 with an obd1 ..and swaped an type R engine and used the obd2 harness hooked everything up and try to start ...key turns but no power ...? checked the fuses, checked battery...everything good...im thinking it might be a harness problem..? any body have this problem or know what it could be,,???
Re: help!!! type R teg motor swap into a 99 gsr..wont start (nicklk)
It' s might be your wiring harness?What ecu are you using? Maybe it's the imobolizer? Both of you get back at me? Let me know what's in been done or not. If you can get a n OBD2 to OBD1 jumper harness from a friend try that to see if it start at least for a start.
Re: help!!! type R teg motor swap into a 99 gsr..wont start (3nhanced)
yeah im looking at the harness. you just said your car is obd 1 but you used the obd2 harness. cant just do that. need a jumper or use the obd1 harness and correct ecu. make sure you swap over all the obd1 stuff onto the itr motor.
