lsvtec
Old Jan 27, 2015 | 04:11 PM
jdog_kustoms's Avatar
Default lsvtec
im looking at building a ls vtec engine my question is i wondered if there are a big issue building a b18a vs building a b18a bottom end for it seem to be almost the same block and head will be a b16 cuase i know the b18a dont flow as well
Old Jan 27, 2015 | 05:33 PM
B20VtecVillain's Avatar
Default Re: lsvtec
Well all flow numbers aside, if you use a B18a head you would just have an LS setup not an LSvtec. Anyway, for the block, other than a slight compression difference which only matters if your using stock Pistons and such the blocks are identical and will not matter whether you use a/b block for the build.
Old Jan 27, 2015 | 05:35 PM
Default Re: lsvtec
ok thank you so much wanted to make sure no sensor holes or ports for stuff not there on the older block for the swap cool cool
Old Jan 27, 2015 | 05:40 PM
Default Re: lsvtec
You can build an LS/Vtec fine with either block. Just get a reputable kit for the Vtec conversion and it will save you a lot of hassle. Also if this is your first hybrid build, two hugely overlooked issues that will cause trouble in the long run:
First make sure the internal Vtec oil passage in the head is blocked. Secondly since these are not a factory Honda produced engine, special attention must be given to properly set the timing and tune your setup. No factory ecu basemap or timing marks will be appropriate for a custom build such as this and you could severely damage the build before you get to enjoy it. Good luck.
Old Jan 27, 2015 | 05:52 PM
Default Re: lsvtec
ok thank u for all ur info
1jdmek
Jun 12, 2023 03:20 PM
91redteg
Nov 8, 2007 03:48 PM
WHITE DEATH
Jun 17, 2007 02:20 PM
91DApwr
Sep 11, 2005 12:10 PM
Hondasaurs
Jul 9, 2003 10:11 AM
